An Audio Guru
- Jan 11, 2012
- 0
- Age
- 38
- Georgia
- Ford
- Engine Size
- 3.0 v6
The problem isn't to bad right now but is geeting worse and need to rectify before Saturday when I make a long drive in it. My truck is a v6 vulcan 5 speed M5OD-R1(I think). The stick has a lot of wiggle room or play in it...more than my last truck did. Occasionally when playing with the stick at lights when in neutral it wont move over in between 5th and reverse. I have to shift into a lower gear to "reopen" that side. When actually driving I will have to play around in 1st and 2nd to get 3rd to open up.....kinda of annoying when in motion/traffic and I have to coast until I can get it into 3rd. When sittin and go to put in 1st it seems like it might be having a small issue that can get bigger getting all the way into that gear too. Basically I have heard of something called a syncronizer before and wanted see if anyone knew anything about it? Where it is? Does it sound like it could be the prob? The trans isn't slipping I think, when its in gear its golden!! Drives great other than a bit of vibration. Truck just got another engine from a Mazda B3000 and got another rear end too. Truck has had a shiz ton of work done since November... Anyway <-- ramble on there. Any help would be appreciated. And if anyone has any other ideas please pitch in. Thanks!!
