M5R1 Rebuild Problems
orangealpine
In the middle of rebuilding a Duratec M5 and am having problems. The main shaft has been removed form the case, but we can't budge the 3-4 synchronizer hub and cannot see the problem. The spilt ring keeper has been removed. Do I need to put it in a press or is it supposed to slide off? Hate to use force when it is not necessary.
Second question, the trans is being torn down because the 2nd gear synchro is essentially non operative. While I have not been able to remove it, the brass ring looks fine. What else could be causing the problem?
Bill
All the speed gears and synchro hubs have to be pressed off.
pcollins
7
Middle of Nowhere, NY
GMC
4.8L
Whats a Duratech M5? Mazda makes the transmission, just sayin.
orangealpine
Good question. In this case, it is an M5R1 that bolts to the Duratec 2.3 engine. I don't know if this transmission is any different than the one used with Lima engine, so I was trying to give the gurus an idea of what I'm working on.
Mazda makes the tranny and designed the engine, if that makes any difference.
Bill
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Bill
It's tight but doesn't need to be pressed
Hold the shaft in your hand by the output end.
Placing a chunk of lumber on the floor now SLAM the shaft down (input end DOWN) against the block of wood.
a shot or two and it should come right off. SOME of them slip off when the retainer is removed.
Do be aware that the synchro collar if not removed before hand will go FLYING (along with the keys)
if you don't remove it first
AD
orangealpine
Okay, we got it all disassembled and surprise! - everything looked fine. I ordered a basic rebuild kit anyway. Parts arrived yesterday. I compared the old and new first and second gear synchro rings and find about 5 thou of wear. I say "about" as there is two-three thou variation in both the old and new parts. The other replaceable synchro parts look fine.
Is that enough to cause synchro failure? The second gear synchro was barely operable, if the double clutch was not spot on, it would grind like crazy. Is there something else that could (or is likely) causing the problem, or should I just reassemble?
Bill
homesculptor
8
Grizzly Flats CAlifornia USA
Ranger FX4 XLT
heavy
I'm having problems finding a rebuild kit for the year 2004. I'm not sure what year mine changed, but the newer transmission has multi piece gears on 2 and I think a few other changes, and I don't know if the synchros are the same. I can't get any answers on this. Anybody have to build an 04 transmission?
