Maintenance Question 4x4 Manual
Warmblood58
Fairfax, CA
4.0L OHV
Maintain it dammit!
I used my 4x4 system yesterday ('93 Ranger 4.0 OHV Manual trans, manual locking hubs, etc) and had some binding without full wheel lock and was wondering from a maintenance standpoint, anything I need to do on this '93 in the front to ease operation? Front diff fluid was just changed, grease points or other? Thanks!
8,370
When you do the ball joints you should also do the front axle u-joints, if this wasn't done then could be where the binding is coming from
1993/4 can have hybrid Dana axle so see which you have, look here: https://therangerstation.com/tech_library/dana_28_35.shtml
If newer u-joints were installed then they "may" have zerk fitting for lube gun, original did not
When doing the front axle shaft u-joints you cannot use a joint press. You have to use a hammer and vice to pop the caps out.
If you use a press you WILL warp the ears, and blow the ends of the new caps apart when you install them. Ask me how I know.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
look up inside where the shafts run through the axle beams and make sure there isn't any trash (tree limbs, rocks, dead animals, etc.) in there binding on the shafts.
