Manifold-to-Cat stud stripped
MSGia
124
Central Florida
4, 5
Good morning all, I’m in the process of swapping both cats on my truck (4.0 SOHC), they both threw codes and now that I have them out it’s just dust in there, no catalyst left. But my question is about the hardware. Out of the 4 bolts connecting the header flange to the inlet of the cats, only one came off still intact so I went to buy more and took the bolt with. I measured the original bolt on the tool they had there l it read 3/8-16, but after a few trips back and forth it seems like no size works. The threads on the header-to-cat studs look fine (at least to me, not too certain 😂), so what should I do moving forward?
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
That’s probably M10x1.5 like most other new Fords.
MSGia
124
Central Florida
4, 5
Thanks, I’ll try it out. Odd because the old nut threads perfectly onto 3/8-16. I have tried 3/8-24 and M10x1.25 so far.
sgtsandman
Aircraft Fuel Tank Diver
12,747
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
You can check out Rock Auto, if you can afford to wait. Last I checked, they had exhaust to cat studs available for my 2011.
MSGia
124
Central Florida
4, 5
Thanks. M10x1.5 works, but two out of the four won’t start threading by hand, just spinning. Any suggestions?
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Roert42
5,018
Kintersville, PA
Ranger XLT
4.0 SOHC
Cut them off, drill them out, and replace it with a stainless steel bolt/nut/washers.
