Manual T-Case swap
jonathon
Washougal, WA
Honda
1.5
So I've been reading a lot here.. Great info I must say. Finally registered after reading here for the last year or so :icon_cheers:
Anywho, I really want to put a manual t-case in my truck(1988 4wd Ranger, A4LD, 2.9L), mostly because I want to and I absolutely hate not having a shifter. I plan on doing hubs at the same time as well..
What I'm wondering is what vehicles usually came with a manual BW1350? Also, once I score the t-case, anyway I can check and make sure it's good before I do the swap? Reason I ask is my Ranger is my daily driver, and I can't be down much more than a week due to my play truck getting about 9mpg. I figure I'd try to do it over winter break when all I have to do is drive to work and not 35 miles to school...
Will I have to worry about any computer issues in an older vehicle like mine?
I been wrenching on my rig since I've had it.. had the trany down a couple times so I figure I could do this just fine.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
I believe the 1350 ended when the d35 started, so somewhere around 89-90. Make sure you get the correct linkage for your rig (a4ld and fm146 will both work, fm145 will NOT because its shorter), the fm146 started in 88 FWIW. Ive *heard* M5OD linkage wont work even though the tranny is the same length as the A4LD and fm146, but I dont know that for sure.
jonathon
Washougal, WA
Honda
1.5
Now that's some good info.... I was planning on doing an FM146 swap eventually anyways, good to know.
By the way.. I'm in Washougal! Nice to know there are others close too :D
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
No electrical issues. The transmission and truck have no idea when your in 4WD, other than the indicator lights that are only there for your knowledge.
They can be re-wired to make the indicators work.
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Man, I have not heard the name NakedDucks since like 2 forums ago.
jonathon
Washougal, WA
Honda
1.5
Well I posted an ad on CL looking for a t-case, wish me luck.
I might've scored another ranger, same as mine with a leaking trany.. thinking that'll be the project that an FM146 goes into. Can't go wrong for strong running and shifting for $200...!
