Manual trans and won't idol down until full stop
gubni
Northeast TN
I have a 98 Ranger 4x4 xtracab with 3.0 V6. 6 months ago we put a clutch in it. 2 weeks ago we put spark plug wires in it. Last week it wouldn't idol down. We replaced the ICV because that always fixes it, lol. It didn't make a difference. I checked for a vacuum leak, but found none. When parked it is slow it idol down if you rev it up. When driving it won't idol down until you come to a full stop. Yeah I didn't believe it until I drove it. So if you are at 3000rpm and push in the clutch it will stay there, but if you come to a full stop it goes down to normal.
I could guess all day long, but I'm curious if anyone else has had the same problem and what you did to fix it.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
It's suppose to stay at higher RPM's until a full stop. It's an emmisions thing. It should not drop to idle every time you press the clutch, if it does THEN something is wrong.
8,370
Yes, +1
Just to confirm, the computer holds RPMs higher when shifting and then they will drop if you hold clutch pedal down long enough but only to about 1,000rpms
Once speedometer is under 5MPH then RPMs should start to drop again to "target idle"
Target idle is based on emissions standards by model year and engine, usually there is a sticker under the hood that will tell you target idle
I used to have a similar issue, but I stopped worshiping idols, and now I don't.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Oh... Come on... Now... You're better than that. :no2:
I was up half the night rolling around the bathroom floor thinking my gut was going to explode. I'm not in full form today.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
gubni
Northeast TN
If I press the clutch in on the interstate at 3000 Rpm it will stay there until I come to a complete stop. Imagine 5 minutes although I have not been able to coast that far.
gubni
Northeast TN
Yes, +1
Ok two things, higher can be much higher and it's a complete stop to drop idol. Yeah I know that doesn't make sense.
RB7 Ranger
5
Tn
3.0 litre
You may want to check alternator amperage output along with any a/c voltage coming into system by way of a bad diode.
also this TSB is very helpful
gubni
Northeast TN
I have no charging problems and it's been going on over a week. That TSB looks like it might be the problem, but I can't fix that myself.
