Wanted MANUAL TRANSMISSION THAT FITS 93 RANGER NEEDED: I am trying to find a used transmission for my 11/1992 Ford Ranger 2.9 L -4 cylinder.
Sloaner4
5
Savannah,Ga.
Ford Ranger XLT
I just bought this truck and I fell in love with it. Honestly when I first bought it I just seen it as a cheap little truck that would get good gas MPG. I am just going through a little rough road as a lot of people are right now, usually I do alright keeping myself caught up on everything. I let my daughter drive my 95 F-150 back and forth to work, she was running hot and just kept driving trying to make it home.(cracked head)/ I was driving down I-16 going about 65 MPH and my little Ranger made a sound like a gear grinding just for a second and it jumped into neutral. Now it will not go into any gear 1-5 or Rev. stuck in neutral. I live in the Savannah,Ga. area and would be willing to drive 150 to 200 miles to pick it up. I live off of my disability payments and am not asking for charity. Just if someone has a used manual transmission that would work it would be a tremendous help right now. I do wood working in a little backyard shop and make lawn furniture out of pvc wood I would be willing to trade the bar height tete-a-tete chairs I just got through building also a $900.00 value. They are really well built, glued, screwed, and bolted and very beautiful chairs if interested in trading transmission for chairs I will send pictures. That way I could maybe pay for shipping with the $400.00, I just really need a transmission for my Ranger. Thank you all for your valuable time to read this I am very grateful for everything in my life. I will not just sell the chairs only, trade for all or fair monetary value on transmission. Thank you all again. Sincerely, Steven Sloan
rusty ol ranger
2.9 Mafia-Don
7,605
Michigan
177 CID
The 2.9 is a V6 that ended in 92.
You probably have a 2.3L 4 cylinder.
Not trying to be a prick but dont go shopping for a 2.9 trans as it will be no use to you
you can try www.car-part.com
NakedDucks
63
B’ham AL
If you'd like, I can rebuild you trans in a matter of 2-3 hours. For $150 in parts.
You *most likely* ran it low of fluid, and it ate the pocket bearing between the input and main shaft. This is an easy fix, and I have plenty of these laying around. Or, I can swap you a good trans for your bad one for $200. I run all 4.0/5.0 stuff, but have a good trans I was gonna use for pics of the case in a future article on the M5OD.
I live in Bham, AL.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
Make sure which engine you have, (pic help) I have a 5 spd for a 3.0 just sitting. It was rebuilt about a year befor the motor exploded. less that 10k on it. If it will fit, come get it. I'm in Tallahassee.
bcschief
32
crescent city fl
2.9
Try LKQ in Daytona they usually have quite a few rangers in their yard. It's a you pull it yard about a mile off of 95. You can also look at their inventory online and see pictures of the vehicles when they went in the yard. A little bit of a drive from Savanna.
Josh B
1,987
Oklahoma
What is "PVC Wood" ? I thought PVC was a plastic pipe.
Do you have a means of changing that transmission?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
ASS U MEING it is a 2wd....they had a few in the 220-280 range at my local yard last i was there....that is in detroit area. so you will likely have the same in your area.
BroncLander
412
BC Canada
XLS Bronco II
Hey man, I really hope a perfect trans comes up for you.
rusty ol ranger
2.9 Mafia-Don
7,605
Michigan
177 CID
PVC wood im assuming hes reffering to that plastic stuff that looks like wood. I believe the proper name is "extrusion" or something along those lines. It lasts way longer then even treated wood but ive heard its a bitch to work with and is pricy.
If this dude makes lawn furniture with it he must have way more paitence then me
