- Aug 13, 2016
- Reaction score
- 0
- Location
- Wyoming
- Make / Model
- Ford
- Engine Size
- 5.0
- Manual
What did you do to run the explorer fuel injection with a standard trans??
A few notes of what I learned along the way in doing the swap.
The Mustang T5 puts the shifter far back between the seats.
The 94-96 F150 5.0L M5OD-R2 puts the Shift further up under the radio.
The TKO500/TKO600 with the Mid-Shift kit put the shifter essentially in the stock location and would be a great performance trans, but are pretty expensive.
The 99-03 F150 I300 Inline Six Cylinder M5OD-R2 installation notes are as follows.
It puts the shifter right through the Rangers stock location in the floor, as this later revision of the R2 has it further back for the differences in the bodies of the newer F150. (this still allows the use of the popular explorer full length console swap, as would the TKO500/600)
The F150 i300 Six shares the same bellhousing pattern as the small block 302, but it has slightly smaller diameter bolts, so you need to drill out the aluminum bellhousing bolt holes one size up to slide the 5.0 mounting bolts through them. (the two locator dowels are the same size on both engines however and these fit just fine.
The F150's Rubber trans isolator mount does not fit the Ranger crossmember, however the Ranger's 4.0l rubber isolator mount does fit the M5OD-R2.
The M5OD-R2's transmission rubber isolator mounting point is 3/4" more rearward than the Ranger M5OD-R1, so you you need to either slot the ranger's trans-member holes, or move the crossmember back 3/4". (I already have Illusive Fabrications Raised trans mount, which fits between the framerails, so I only needed to slide it back 3/4" and drill two new holes.
You must use a manual SHORT NOSE starter, and a 164 Tooth Flywheel with this transmission.. You must, so make sure you have the right parts... If you are using a 96-2001 Explorer/Mountaineer 5.0L you MUST make sure you are using a 50oz flywheel (the 94-96 F150 5.0 is a 50oz).. Any other 302 setup you are using make sure weather you need 0oz, 28oz, or 50oz balanced flywheels.
My truck was already a OHV 4.0l Manual Trans 2wd, and found that the slave cylinder, and rubber isolator fit the M5OD-R2 and the driveshaft length and splines matched right up (even though I do have a custom two-piece longtravel slip shaft on my bagged/4linked setup, it was made to the stock overall length and was previously on the 4.0's M5OD-R1, so the stock shaft should work as well), the 2.3L, 2.5L, 3.0L, and SOHC 4.0L or 4x4/Torsion variations may or may not fit, I do not know the details on the interchange there unfortunately. As well as any differences in the 01-11 Rangers, I can personally only vouch for the 98-00's for this particular swap.
The 99-03 F150 i300 M5OD-R2 is very plentiful and very cheap. I had no problem finding dozens of them in my local wrecking yards or on car-part.com.. The vary from $80-$300 consistently, and I bought mine for $130 with 45,000 miles on and they included the engine plate, shifter, and starter for me.. You can't get a cheaper more bolt in solution for a manual 5.0 swap in a ranger.
The earlier gen 94-96 F150 5.0L M5OD-R2 is an option, and should work just the same other than the shifter locations being further forward into the dash, but I wouldn't bother with them as the newer 99-03 version fits better, is 10 years newer, is likely to have much lower mileage on it, will be cleaner, and only cost $100-$200, it's really a no brainer to go with it.
There are all the rebuild parts available for the M5OD-R2 for affordable prices, it can be had with a 4wd transfer case if wanting a manual 4x4 (see the Bronco forums for info on the 4x4 versions guys are using for thier 5.0 builds)..
There is a cnc'd billet short shift kit with hurst shifter available from a company on ebay: http://www.ebay.com/itm/Core-Hurst-shifter-for-1999-2008-Ford-F150-truck-w-M5R2-5-speed-M5OD-R2-/281862654258?hash=item41a052c932:g:4EEAAOSwlV9WT4wX&vxp=mtr
