Junk Collector
Truck of Month
- Mar 4, 2008
- 4,842
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Here I am again with another obscure problem...
I put that 2nd gen dash in my '88 Ranger along with 2nd gen pedals. I had an assortment of master cylinders, hoses, and whatnot to use including one that I think was from an Explorer. I had to use a different hose (different quick connect fitting on the slave) but it all went together fairly well.
Here's the issue:
When I push the clutch pedal in, the push rod does not travel far enough into the master cylinder to engage the clutch switch completely. It needs to travel approximately another 1/4". Additionally, I believe this is also an issue for the clutch itself - I do not think the clutch releases all the way. With the pedal pushed in, it is hard to get into gear and the driveshaft begins spinning (wheels off the ground.) I don't believe this is an issue with air in the system, I am pretty good at bleeding them... I think it is either a push rod length thing or possibly the firewall itself not having proper clearance for the master cylinder to bottom out because the pedal hits it.
I measured other push rods I have and they are all actually shorter than the one I'm using - around 7" vs 8-1/4". I don't believe a shorter push rod will help.
Has anyone run into this before? I know I kinda have a hodgepodge of parts going on here... my two thoughts at this point are to either grind off the back of the clutch pedal so it travels further before it hits the firewall, or make my push rod even longer - that may not work though, I will have to look but I imagine the pedal itself about at the top of its range of travel already.
Here's the issue:
