- Aug 8, 2007
- 4
- Age
- 58
- Shawnee, Oklahoma
- Ford
- Engine Size
- 4.0
I'm hoping I can get some guidance on my brake. Here's a brief histor that since the issue started.
Last fall I bought and installed Dana 35 beams with Dana 44 Outers on my 89 BII. During the install I replaced the rotors, calipers and pads with new ones. After the install the brake pedal traveled further and didn't seem as strong. Not long after I swapped the drums on by 8.8 to disk. After this the braking got even worse so I changed the BII master cylinder out for one from an Explorer with 4 wheel disk and removed the RABS moduel and there has been no improvement.
I am using the original BII hard lines and bought the extended stainless braided lines from Duff. I also purchased a Motive Products power bleeder. I have bleed the brake numerous times but braking remains the same.
Do you think that a master cylinder from a 1/2 would fix this issue and get my brakes back? I would like to get this solved so I can start driving this again plus I have an off-road trip coming up that I won't be able to do without brakes.
Ideas?
Steve
Ideas?
Steve
