Surging
thanks guys, that's good then for an engine that's 22 years old. the reason i am going through all this is because my engine is surging esp when i first take off from a start it idles well though. i changed the plugs a year or so ago and then i changed them a week ago it was really running ruff before i changed the plugs all 6 were a covered in dry black sooty substance. a few months ago it would just quit running on me altogether i changed the ignition module and that fixed that. since then i have replaced the egr valve and cleaned out the manifold vac port cause it was completly stopped up i also changed out the air filter,fpr,02 sensor, inline filter about 4 months ago and canister filter and low preasure fuel pump and strainer. when i replaced the pump i noticed the hose connecting the pump to the sending unit was dry rot and the strainer had the black rubber stuck to it some of the rubber is still in the bottom of the tank as i took bed off to change instead of dropping the tank so i couldn't get all of it out. could that still be my problem or do you think it might be something else? Also 1 more question when i did my compression check when i turned over the moter the guage went to about 90 then 120 then 140 then 175-180 is that also normal? hey guys i really appreciate al of your help i jsut feel stuck!
First off the compression test does exactly what you describe in all engines. 175/180 is what we expect to get on a good running engine.
You don't describe the "surging" well enough to trouble shoot your problem.
1. Does it surge while idling?
2. Does it surge at part throttle?
3. Does it surge at wide open throttle?
4. Does it surge at steady hiway speeds?
5. Does it surge when going up a hill at full throttle?
5. While surging does it backfire?
6. Does this surge happen only cold..or hot?
Help us out here we need as much information as you can give.
Big JIm
