b23
- Jan 11, 2013
- 0
- mazda
Mazda B2300 low oil pressure bad economy
I recently bought a 96 Mazda b2300, body is straight, some surface rust on the bumpers but overall great shape. Will be using it for a work truck in here in Phoenix
(edited this post with my NEW problem)
NEW PROBLEM!
My main concern now is the oil pressure gauge is only reading about 1/3. It doesnt seem to matter if its cold or hot, load or no load, highway or city - its about 1/3. I have no "Check Gauges" light (I do have a CEL though, for the MAF).
I have nothing to indicate I actually have low oil pressure. There is no pinging, ticking, or other valve noise. Everything seems lubricated and the engine runs like a top. My next step is to test oil pressure with a mechanical gauge to verify my thought, that the sensor is bad.
I have an oil leak somewhere. It appears to be from the valve cover, I hope not from the head. With cast iron heads a blown HG wouldnt be the end of the world, but its a hassle I would like to avoid if possible.
Another concern I have right now is the fuel economy seems a little under par. Highway driving I got about 110 miles with about 1/3-1/4 of a tank. Is that about right? $44 into the tank to full, looks like I will get about 350 or so out of the tank? How many gallons are even in this tank? Base model (no extended cab or extended bed) 4 cylinder B2300
ANOTHER PROBLEM
I am having some stuttering when coming to a stop, the car wants to stall even with clutch in. One time pushing the clutch in made it stall.
I am also having some "bogging down" - loss of power, when I floor it in a low gear. It will soon pick up and haul ass like no 4 cylinder should, but bogs down when you floor it just for a second or two.
I am also getting some backfiring.
I think the above problems are a combined issue of bad fuel injectors and bad MAF. The bad MAF is not reading properly, negatively affecting my mpg. Coupled with that, the fuel injectors could be clogged on a few cylinders. This could cause them to not be closing all the way, causing them to squirt without throttle.
This could be causing it to flood a little bit, causing the engine to "want to stall" when I come to a stop, even in N
It could be doing the same when I floor it, dumping too much fuel and flooding thus losing power for a second before picking up
It could also be dumping fuel in when it shouldnt, which then drops to the exhaust, hits the hot exhaust and burns there, causing the backfiring
Sorry for the long post - I have a lot to say! Any help, tips or advice is appreciated! Even if all you have to say is I am going down the right path diagnostically, it will help a lot!
Got the truck for a decent price assuming these problems are easy to sort out. I can do the work myself so will just be paying parts. Any help appreciated, thank you!
NEW PROBLEM!
ANOTHER PROBLEM
