Mazda to Ranger Trans Swap?
1984Ranger
Alaska
V6 2.8L
Hello, I have a Mazda B2600 Manual 5-speed 4x4 (Not sure on year. Maybe a '98? Will find out tomorrow if necessary), and a 1984 Ford Ranger XLT 4-speed 4x4. I was curious about swapping the transmission, clutch, etc... Is it possible? If so how would I go about doing it?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
You will need the clutch master, reservior and the hydraulic line that goes to the slave. Basically the entire system, but should be bolt in...
SVT
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Not possible. The B2500 (4 cylinder) has a different bellhousing pattern than V6s and the bellhousing is not removable from the transmission.
gribly
28
Maine
Honda
K20A3
If it really is a 2600, then it's not even related to the ranger family, and is no newer than a '92.
scotts90ranger
4,543
Dayton Oregon
2.3 Turbo
if it's a B4000 then the tranny will bolt to the 2.8... but you would want to use the stock transfer case so the speedo would work.
Rose2300
7
ID
Toyota
3.4
a mazda b2600 is a mazda product is in no way related to the rangers
3,614
Yeah, the B2600 was a Courier relative, in all it's iterations. It was never a Ranger.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
What all the above had said. I had taken for granted that both your truck and the donor were both 4 cyl's since you never stated what your truck was. I completely missed your info under your avatar....Now, if it truely is a late 90's mazda, then you will have the B2500, not the 2600. In 98 they had the 2500, 3000, and 4000. The 3000 trans bellhousing is a different pattern and will not bolt to the 2.8L, 2.9L, or 4.0L, which of these 3 all share the same pattern...
SVT
1984Ranger
Alaska
V6 2.8L
Well, the Mazda says B2600 on the side of it.
Engine looks like this:
Says 08/88 on the specs. Sorry for the confusion.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
its an older one, and won't work, entirely different setup...
SVT
1984Ranger
Alaska
V6 2.8L
What would be swappable in it then? (Already got the seatbelts from it in my Ranger)
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Not much, it would be like trying to swap chevy parts into a ford....
SVT
mp3deviant721
24
Eau Claire, WI
2.3l of fury
I read somewhere that the rear axles are about the same width.
1984Ranger
Alaska
V6 2.8L
Eh, Alright. Maybe I'll just turn the bed into a trailer. Hahaha. Thanks anyways, guys.
