mile marker manual hub??
redneckbl89
lincolnton,nc
Mazda
anyone know where i can get the o-ring seals for the back of the hubs where they fit against the rotor.
mhughes165
9
302
use RTV, the rubber seals never work properly
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
PT# FOTZ-1K106-A
You can get it at the Ford dealer.
Capt Jay
25
Minnesota
'93 body.
Ford(ish)
302
I just use RTV also. The stock seals don't work well and break all the time.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I think carelessness is what breaks (actually cuts) them (maybe from the hub being loose while putting the wheel on?)
I've never had an issue with them myself, although I did find one of them cut on my friend's truck after he had some work done on it.
