Missing floor on 1988 XLT extended cab
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Ok, long time reader, first time poster.
Went to fix what I thought was a quarter sized hole in my cab floor, and wound up with my entire floor and most of the part that mounts the cab to the frame on my driveway. Attached some gore photos.
So before I resort for looking for a cab, I'd like to try to repair this one first.
Planning on picking up a cab floor. Anyone know of someone who sells/makes a floor pan with the supports fabbed into it? Or, anyone in Pittsburgh that feels like fabricating one for a case of PBR? [emoji23]
Thanks all!
Sent from my H8314 using Tapatalk
17,851
SW Iowa
I haven't seen anything. I am doing the cab floor on my '85 right now and thankfully my support looked fine.
You need to pull the carpet and see how everything else looks. If the passenger floor is in the same shape you might be better off to to do a ctrl-alt-delete and start over with a different cab/truck.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Already did and done. Floors and surprisingly rockers, etc in the rest of the cab are perfect. Looks like there was a windshield leak years ago that was never corrected until recently.
Yup, quarter sized hole. Quarter panel.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
[emoji58]
Yeah, as it turns out, what I thought was the floor was the factory installed asphalt noise barrier shaped like a floor. Thought the road noise was becoming excessive.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
looks familiar.
you will have that with these.....:icon_welder:
its just metel....make it mo betta....
[emoji58]
FYI, that won't pass inspection.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
This is why i will never pull up my carpet. It looks solid from underneath and i dont fall thru. Im happy.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Bird76Mojo
1,265
IL
Holy crap. I thought my 2001 from Ohio was bad. My 87 from Michigan/Indiana looks brand new compared to that.
Did you already replace the cab mount, because that sucker is COOKED. Done.
As for the floor pan, a simple Google search will find you one. They're two separate pieces, passenger and driver..
Oh, and as a general rule, when you find a pin-hole (literally pencil lead sized) the rust on the other side of the panel, that needs cut out, is usually at least the size of the palm of your hand.
GB :)
GB :)
And that is a geometric progression as the actual perforation. gets larger.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
I'd be looking for a different cab to replace that with.
These trucks are not yet exactly rare in junkyards, finding a cab for cheap should be pretty easy I would think.
Moved to Exterior, since this post pertains to the body structure itself.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah....not around here mang.
you go ahead and mail me an 88 ext cab and i will use it. cause mine is worse.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
GB :)
Actually, I started this post because I cannot find a cab mount. Any suggestions??
