mn_smokeater's Bronco II resurrection Build
4.0B2
151
Walls, MS
4.0 v6
So the 2.9 gauges worked fine for my 4.0 swap. Don't know if that means anything for you.. Lol. Not really reading everything since I'm in class at the moment.
Main point-- SUBSCRIBED!
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
so might have a possible idea. a 3.0 B2
Clay Lorance
10
Elwood,Texas
4.6 V8
Good luck with the build smokeater.
3,614
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
Try going for a 3.0 DOHC if you do it.
Your biggest issue will be finding a 4x4 trans for it.
engine iv found is a 05 3.0
how hard are the trans to get?
4.0B2
151
Walls, MS
4.0 v6
why a 3.0 instead of the 4.0?
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
TheTopher
176
Delaware
2.3
A one-off, ya say?
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
some thoughts have kicked out! with help from Hoosier!
5.0L GT-40 from expo with torque monster headers
Fuel tank i think maybe custom
HID headlights and Foglights
Custom dash
TheTopher
176
Delaware
2.3
You've resurrected your resurrection thread. Well done. :icon_cheers:
Colin
184
ON Canada
Mazda
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
got 2 vids coming up where il discuss the plans i have
Beef52751
13
Eastern Iowa
2.9
5.0 bii ftw!!!!
