Moog adjustable camber bushings for 88 BII
n_grimm
I'm wondering if I ordered the right Moog bushings. The number is k80153. The picture looks like it is adjustable but now I'm not sure. I thought they usually say "0 to 3-1/4" etc. The description says: adjustment range -3-1/4 to 3-1/4 deg.; Front; 4WD
http://images.oreillyauto.com/parts/img/medium/moo/k80153_top.jpg
Any help is appreciated.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Rockauto.com lists K80153 for a BII also (and shows that same pic), so looks like you got the correct one. :icon_thumby:
n_grimm
Does it look like it is fully adjustable as in 0 to 3-1/4 since it doesn't actually say so? I've never used one before. Thank you for the reply.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Looks like a 2-piece fully-adjustable bushing to me.
n_grimm
I ordered them from Rockauto and they made it here yesterday. I was able to get one in the drivers side today. I raised the B2 about an inch and it took about two degrees negative camber to get it right. It appears to me there are some settings you can't possibly get since sometimes the tabs on the outer ring get in the way. I didn't know if I should cut the offending tab so I just picked a happy medium instead. Thank you for your help.
rusty7983
Hohenwald, TN
How hard are these bushings to replace? What steps are involved?
