motor mounts
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
95 Ranger - 2000 Mustang K member - Cleveland Block, Toploader Trans
Hope all is well out there!!
getting ready to establish motor mounts on to this K member (custom fab mounts) and started thinking about vibration elimination as opposed to a hard mount to the K. I had purchased a poly Trans mount for the toploader support and was impressed by what appears to be a "stout" piece. So now I'm wondering if I were to incorporate 2 of these pieces into the custom motor mounts if they could handle the "motor abuse" too??? No response from manufacturer so I'm puttin' it out there to the "real" experts! Thanks
Junglejoe
66
Columbia Missouri
6.0
They say you're not suppose to mix those up.. meaning transmission mount polly and engines rubber..or vice versa
smilinjack
34
rochester, mi
ford ranger
408C
2"
Thanks Joe. Are you aware of any science or application of that theory? Looking at these things, it just doesn't seem like rocket science.:cool:
insaneranger
42
Tennessee
302
225/40 R18
I would suggest going all poly or all rubber. The rubber motor mounts allow a certain amount of flex, but the stiff poly trans mount refuses to flex as much & could cause the trans mount to crack or break. The engine & transmission are bolted together as a solid unit & should be able to flex as a single unit under torque.
JOLENE_THE_RANGER
204
long beach, ca
poly works well ive been using these for about 6 years in a offroad race application. they have various year and engine combos on the site. sounds like you might have installed a 302/5.0? im pretty sure they have the right ones for you highly recommend em!
link is just an example..
smilinjack
34
rochester, mi
ford ranger
408C
2"
Thanks for the replies. Both are appreciated. Actually I did (am in the process of doing) a 408 Cleveland. Looks like I'm goin with solid motor mounts.
I've decided to install "hard" rubber (70 durameter rtg.) pads between the mounts and the k member brackets. I think those will pair with the poly trans mount. Not perfect but a little better.
Junglejoe
66
Columbia Missouri
6.0
Yeah if you do rubber mounts and a polly trans mount.. youll more than likely break the transmission tail housing
