RumpRanger98
- Feb 19, 2009
- 2
- Tacoma, WA
- Ford
- Engine Size
- V6 3.0L
So I had my cousin (owns his own shop) pull codes from my transfer case. It has been having intermitent problems of going into 4wd on its own, lights flashing when turning key on once in a while..etc
Here are the codes pulled:
P1832 Transmission transfer case differential lock-up solenoid circuit failure
P1838 Transmission transfer case shift motor circuit failure
P1850 Transmission transfer case contact plate B circuit failure
P1854 Transmission transfer case contact plate C circuit failure
P1866 Transmission transfer case system concern - servicing required
P1878 Transmission transfer case disengaged solenoid circuit failure
Currently the 4wd system is running fine now. I took it down a couple gravel alleys and put it in 4HI and 4LO, back into 2wd, back through 4hi, 4lo....everything atm seems to be fine.
Do you guys think all of these codes are telling me my electric transfer case is on its way out?
I was thinking of getting the AVM hubs because I was thinking it could be the auto hubs causing my problems. But with all those codes it looks to me like my electric t-case is on its way out....let me know what you guys think. I believe my cousin said he could get a reman replacement for around $120 or something like that.
Thanks,
Thanks,
