mustang headers
gfbgreaser289
in the woods
turd
FORD
i have searched a lil bit and didnt find much of anything about mustang shorty headers. has anyone used these on there small block swaps. i have a efi 327w :3gears: with a t19 4speed. the motor is raise up about an xtra inch and moved forward.
88mudder
waterford michigan
My buddy ran factory mustang shortys on his 302 b2 swap and they cleared everything no problem. steel plate, drilled holes in it and set them ontop the factory mounts.
2.3splash
The Fox body mustang headers normally hit everything in the ranger swap. Frame rail on passenger side and steering box on the drivers side. Unless you get the motor up really high they don't work. And if you get the engine that high lots of other stuff is not right.
COPPERHEAD85
41
west tennessee
302
you'll have to cut the front tube(drivers side) about 3 inches from the collector and cope the tube at the flange and kinda tweak it down a little to clear the power steering pump.weld it back up..........worked for me
gfbgreaser289
in the woods
turd
FORD
thanks boys. i have about 3 inches under my oil pan so im going to try it and see if it works
88mudder
waterford michigan
yea mine are cut and re-welded and clear everything just fine.
