My 31s are rubbing in the front when turning hard.
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
I think I found the rubbing on my newly installed 31s. I'm almost certain its the stock mud flaps in the front. If I remove the inner stock mudflap in the front wheel wells, will there be any openings for shit to get in once removed. If so I'll deal with the slight rubbing when turning hard.
93 Ranger XLT 4x4 SC
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Or any other advice?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,547
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Front mud flap?
I've run 31's on those trucks for many many miles. It was rare to get any kind of rub... a couple times at the extremes.
Does it rub at steering full lock?
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
@Uncle Gump . Yes, It rubs making hard full turns only. It's more on the drivers side then the passenger side. Could it be a front end part that it's rubbing on? I'm not 100% sure that it's the inside mud flaps yet.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
@Uncle Gump , Basically I'm cautious as not to turn too hard. My question was do the stock mudflaps when removed create any openings in the wheel well, so shit can get in, salt, dirt etc? I'm too lazy to remove and check them,, and it's too F...g cold out.
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
I had an 89 STX that I put 31" tires on. It would very slightly rub at full turn. As I recall, I found the front of the tire would just barely touch the frame. I never worried about it because it never did any damage even when in very rough stuff off-road. I also made an effort to not turn the wheel all the way, but if I needed to, I would.
It had plenty of clearance to the front mud flaps. The 89 STX had a factory 1.5" lift in the front, so that may have help with the mud flap clearance.
Uncle Gump
Token Old Guy
13,547
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Yeah... iwouldnt remove any flaps or shields. I would simply stop short of the rub.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
So if I remove the liner mudguard it could compromise the well?
Uncle Gump
Token Old Guy
13,547
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Well mud flaps and splash shields are all put in place to prevent water and debris from intruding a given area.
Junk Collector
Truck of Month
4,854
Rapid City SD
Same wheels & same size tires & same front axle here - they rub on the radius arms on hard turns. I think a small spacer might fix it but I just live with it for now.
Blmpkn
Toilet enthusiast
6,376
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Ranger850
Doesn't get Sarcasm . . .
4,698
Tallahassee Florida
Stock 2"
Stock
Shoulda just went with 30" tires.
Blmpkn
Toilet enthusiast
6,376
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Ranger850
4,698
Tallahassee Florida
Stock 2"
Stock
