turbo cat
- Aug 10, 2008
- 2
- city of rain wa
- exploder
- Engine Size
- 4.0ohv turbocharged
Actually its called compound turbocharging its how some diesel engines are capable of 150+ psi (not that i need high boost) theoretically the boost threshold should have been lower. When you feed a turbocharger compressed air it dosent add boost it multiplys pressure ratios. Theres a special formula around to figure it all out. Most compound setups usually also compound the exhaust side (travels thru the first high pressure turbien then the low turbine) Compound turbocharging can work but I woudl have to make a quite few adjustments to get it going...I just like experimenting thats all.Are both the turbos the same? if they are why even bother with the tube connecting the two pipes together. Run one turbo for each side.
Ya Series won't do you much good. Looking forward to seeing the new piping.
