My 83 Bronco Trail Rig
Deviousfred
El Paso, TX
302
Here is what I currently use to go wheeling. It does fairly well considering its not much more than a lightened Bronco on 35's with stock gearing. It has a 300ci inline 6, C6 trans, and NP208 t-case.
In the very near future:
-Softer, Longer Coil Springs
-Heim'd, Extended Radius Arms
-Welded D50 Center Section Swap w/ Stub Shaft (4.10s)
-Lincoln Lock the rear and swap in 4.10s
-Remove overload spring from leaf spring packs
-F-250 Shock mount mod with longer shocks
I would say I have 70% of the parts to do the listed modification, the only thing I am really missing is time. :bawling:
This is the Bronco when I picked it up for $500
Pulled the motor to replace rear main seal and upgrade to the EFI dual exhaust manifolds. Also took some time to clean it up and give it a new look.
Before
After
Built a set of half doors for it
Gutted the interior and moved all my electronics inside
Shakedown off-road run
The old college try
Fail
Fred
Welder0800
West Virginia
1988
That is one of the coolest looking 300's I have ever seen. I'm guessing that's bed liner on the valve cover,pullys, etc..?
Deviousfred
El Paso, TX
302
Its actually wrinkle spray paint they sell at Autozone. I enhance the effect by setting it in the sun then baking it in the oven when it has reached the desired wrinkle.:icon_thumby:
jhammel85
Guest
Nice! I like what you did with my motor.
Overall, its really cool..I love that gen Bronco.
Vanner1993
New Jersey
460, 351M
Just awesome, makes me want a bronco haha
Deviousfred
El Paso, TX
302
Went out for a little more wheeling today. Only got a couple of shots and a video that I will put up later.
4.0B2
151
Walls, MS
4.0 v6
Deviousfred
El Paso, TX
302
Ran out of memory just as it gets to the good part. Click on picture for video.
