My 94 Knocking, Coming From The Belhousing
Drg racr
Southern Michigan
My 94 4.0L is knocking, and it's coming from the belhousing area. I used a stethescope and it's loudest where the starter goes into the housing. What could this be? I've driven it like this for about 4 months now, so if it was a rod it would have blown by now. It's barely noticable when cold, but gets louder when warm. I can really hear it between 2500-3000rpm. It sparks-knocks like mad too all the time too. I think I'll pull the motor next week, but is there anything I should look at first? TC? Flexplate? :no2:
MAKG
19
California central coast
I'd be concerned about the flexplate being loose or partially broken.
BobR
okanogan
ferd
X2 or a cracked friction plate or fltwheel if its a 5 speed. if you don't pull it apart you'' soon be walking.
Bob
Natedog
5
CA
Yup loose or cracked flexplate.
Drg racr
Southern Michigan
Well, I'm pulling the motor this week. I have a lot of the stuff loose, but I can't get to some of the belhousing bolts, or the TC bolts. Ideas?
MAKG
19
For the bellhousing, use lots of extensions and a U-joint.
For the torque converter, rotate the crank with a ratchet on the harmonic balancer bolt.
BobR
okanogan
ferd
Drg racr
Southern Michigan
Well, I got the motor out and apart. So far, the crank is scarred, but nothing else. THe pistons look good, rods good, heads fine, no cylinder ridge (after 132000 miles), so I can't figure out what took a chunk out of the thrust bearing.
I'm going to run the 410 Comp cam in it, as long as I have it apart. Should I do anything else, like head porting, larger injectors, headers, ect? This is mainly a winter truck, but it's in really good shape for a 94.
Drg racr
Southern Michigan
Well, I can't figure this out. I'm thinking of just buying a reman shortblock and hoping it will take care of it. I really don't know what to do yet.
camping_mailman01
If you haven't done yet, I'd replace the oil pump at 132,000.
Drg racr
Southern Michigan
A new oil pump was in the plans. I always replace the oil pump when I have a motor apart.
Drg racr
Southern Michigan
I've got the parts to put my 4.0L back together. Problem is, I don't feel that good about reinstalling it if I didn't find the problem. I can't find a darn thing wrong with it! There's got to be a cause as to the knock.
MAKG
19
You never said....
is the flexplate OK?
Drg racr
Southern Michigan
Oops, sorry. The flexplate looks fine, I can't see any cracks in it. Just a thought, could the torque conv. cause a knock? It was around the same time as the knock, that the TC lockup decided to quit working. It would lock up when cold, but when it warmed up, it would kick back out.
Also, another thought is, I noticed some vibration lately. Not a lot, but some. One guy looked at my bearings and said it looked like either too much endplay or a balance problem (harmonic balancer). That might explain the chunk taken out of my thrust bearing.
MAKG
19
A cracked flexplate or unbalanced torque converter might also do something like that.
Is the flexplate ROUND?
Is there any evidence of a bent crank?
