My brakes are still spongy and not working after replacing nearly every part possible.
joshur21
Holland, Michigan
I have replaced my brake master cylinder, brake booster and check valve, and rebuild my front brake calipers. I also replaced the hard line running to the rear drum brakes due to rust. I went and bled the system multiple times and it appears to have no air in it. However with the truck running it has little to no resistance and with the truck turn off there is pressure, but the pedal this goes to the floor fairly easily. There is no visible fluid leaks anywhere as well and I bench bled the master cylinder before installing it. The truck is a 1988 Ford ranger with the 2.9l Engine and No ABS. Any Help would be much appreciated. Thanks!
Josh B
1,987
Oklahoma
Have you recently changed Calipers or wheel cylinders? The last "new" calipers I got leaked down inside
Ranger850
Doesn't get Sarcasm . . .
4,695
Tallahassee Florida
Stock 2"
Stock
I would check the rears for leaking wheel cylinders,
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Did you get NEW parts or REMANUFACTURED parts? I'd trust a reman master cylinder about as far as I could throw it.
New ones aren't always great either.
Last new master I bought had an incomplete casting in one of the line ports. It was supposed to accept a double flared line, the center hump was not present, and the hole didn't penetrate to the fluid chamber.
Locotomb
62
Puyallup, WA
2.3l
6inch custom fab lift/86
Bagged 3 inch custom drop beams 88/89 Custom triangulated and step notched rear
35/12.5/r18
Everything looks better lower
Maybe your rear drum adjusters are slipping.
