My build thread
shadow88
CLOQUET MN
FORD
shadow88
CLOQUET MN
FORD
I'm using the same pitman arm as you the fa600, is you drag link touching your outer left tie rod?
Harley
Oregon
Ford bronco 2
2.9
5.5 in susp 2 in body
No...it's real close though
Sent from my SM-N900P using Tapatalk
shadow88
CLOQUET MN
FORD
If you can take a pic, I'm thinking I might have to do something different
Harley
Oregon
Ford bronco 2
2.9
How much lift do you have? Maybe you need the 400 arm?
Harley
Oregon
Ford bronco 2
2.9
shadow88
CLOQUET MN
FORD
is it this close?
1RangerNut
Central,IL
2.9L
My steering is real close to touching also with a 4" lift.
shadow88
CLOQUET MN
FORD
Mine is touching, it's rubbed it to clean metal
shadow88
CLOQUET MN
FORD
Ranger nut what pitman arm are u using?
1RangerNut
Central,IL
2.9L
Harley
Oregon
Ford bronco 2
2.9
finally got that nasty muffler replaced, now it sounds good! next weekend if its nice, im going to rip out the interior and clean the carpets and redo the headliner...looking forward to that...
smccrory60
Dillon, CO
2.8 V6
I should have my new headliner material later this week. I'll let you know how installing it goes!
