My engine has gremlins (read below)
tommo77
Firefighter
EMT / Paramedic
Maine
So I got a ranger on the cheap but the motor is 'funny' idles 'ok' runs ok some times, then some times it's rough as guts. Attached is the stored codes.
Changed the maf, plugs, wires, and coil.
Maf reads 0 signal on my blue drive scanner.
And some times randomly the CEL blinks slowly for a few min then goes back to solid on.
My question is, can it be a timing issue? ( I guess the timing chain was done over the winter before I got it.
Could it be a fuel or vacuum problem?
Any help is greatly appreciated.
Thank you in advance.
rusty ol ranger
2.9 Mafia-Don
7,765
Michigan
177 CID
tommo77
Firefighter
EMT / Paramedic
Maine
What year and how many miles? SOHC or OHV?
2004 230k not sure if it's ohc or ohv. It's belting down with rain at the moment once it stops I'll go have a look.
rusty ol ranger
2.9 Mafia-Don
7,765
Michigan
177 CID
Eh all 4.0's were SOHC by 04.
Im not sure if a timing chain issue would cause that. With that many codes it seems maybe its a wiring or ecm issue. Someone who knows them more will be along to help more
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
Doesn't sound like a timing chain issue. It would be consistent and either run crappy or run decent. Seems like an A/F problem.
tommo77
Firefighter
EMT / Paramedic
Maine
Yea, if anyone knows what voltages I should get on the maf that would be helpful, I can't find a schematic for it but I'm getting 14v on red and 5v on the light blue on the opposite side.
superj
2,735
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i guess its a heated wire maf? not a swinging barn door style?
google brings nothing on what readings you need?
tommo77
Firefighter
EMT / Paramedic
Maine
I think it's a wire type, Google is less than clear. I'll keep looking I just figured someone might know what reading I should be getting to determine if the ECU is junk or there's a wire issue
rubydist
872
Denver
Ford Ranger FX4
The mafs issue is the primary one - you need to fix that first. It could be a bad wire in the harness, a bad connection, a bad mafs, or a bad pcm. Once you get that sorted out, the other issues may go away, else you can tackle them one by one.
tommo77
Firefighter
EMT / Paramedic
Maine
That's what I'm thinking I just need to figure out what wires go where and what signals I should be getting
rusty ol ranger
2.9 Mafia-Don
7,765
Michigan
177 CID
5v should be the reference signal...14 coming out is probably the actual reading signal. And seems oddly high but im far from expert
tommo77
Firefighter
EMT / Paramedic
Maine
That's a picture of the wires im guessing red is normal battery / alternator voltage and the light blue opposite is the 5v. Then there are 3 others excluding ground that have no signal. My next guess is to unplug the ECU connection and tone out each line for continuity but that's a stab in the dark
tommo77
Firefighter
EMT / Paramedic
Maine
Ok so attached is the diagrams I believe are for this truck.
I have continuity for the maf return signal to the PCM (light blue/tan)
So I'm leaning to the PCM being faulty?
tommo77
Firefighter
EMT / Paramedic
Maine
Ok so since it's not raining I've done some probing.
All wires to and from the PCM are fine. I unplugged the maf and truck runs fine no misfire codes, just the code for the maf being unplugged.
I'm really starting to think the PCM is junk.
