RoidedRanger
- Jun 21, 2010
- Reaction score
- 1
- Location
- Lakeland FL
- Make / Model
- Ford
- Engine Size
- 4.0
- Manual
im finishing up my stealth 3" snorkel setup for my MUD ONLY 99 explorer sport. after my original snorkel design let in mud/water after some hard mudding I decided id make a better design. original design basically ran out of the airbox and along the frame rail and went in place of the A/C drier in front of the heater box with 3" PVC. new design is a full snorkel but instead of running up the side off the fender and up the windshield (I personally don't like the looks of that) mine runs into the cab, IS TOTALLY CONCEALED, and allows the use of A/C.
my setup comes out of the airbox and along the inner fender (behind the fender). it goes into the cab down where the floor bends up into the firewall. It then turns and ends behind the glovebox and is at the same height at the bottom of the radio. I had to cut 2 3" holes, one in the cab and one for the airbox on the inner fender. I also had to cut the obvious hole in the airbox. the boxed section of the inner fender had to be partially cut out so the pipe could sit close right between the fender and the inner fender. I had to remove the control box on the kick panel for the SRS. also the large portion of the glovebox storage had to be removed since this is right where the riser of the snorkel resides. all in all it was pretty easy to do.
