My Manual Transmission sounds like an idling diesel
96firephoenix
Indianapolis, IN
I've observed this condition in neutral, parked. No way to observe while driving due to wind/engine/road noise.
Clutch is pressed (disengaged) from about 0:09 to 0:12 and 0:20 to 0:22
Edit to clarify: this is a 2002 Explorer 4.0 V6 5 speed manual with 4x4
https://www.youtube.com/watch?v=XxZLcveqlWA
This is making noise in the opposite pattern of a bad throwout bearing.
One of my co-workers suggested that it may be the input bearing... any thoughts or experience in the matter?
Also, Diesel Idle for reference
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Indeed it sounds like a bad bearing on the input shaft or possibly the countershaft.
96firephoenix
Indianapolis, IN
Thanks...I did spot a heat shield that has fallen off the exhaust and is almost touching the trans. I'll straighten it out before I get into the tranny, as this wouldn't change with the clutch in or out, I would think.
