Welcome to the shit show.
Drilled a hole in the side of the shop and brought the waterline up from the ground and into the building.
I used 3/4" PVC pipe from the 3/4" Pex in the ground and wrapped it in insulation and ran it up through a piece of 4x4 vinyl post to further protect it.
I wanted the post to be against the building, but there was to much concrete coming out into the yard from the slab / foundation.
For some reason I thought, hey I'll add a spigot here.
I am probably going to hate myself for using PVC instead of PEX at this point.
There's a T where it goes into the building, and the line into the building is 1/2". It runs to where the old line is and then transitions to the 1/2" PEX I already installed.
Now for the problems:
This spigot has a vert slight leak. I'm finding conflicting information online about how to seal it. It's a PVC male thread going in to a brass female thread and I used Teflon tape. I just read online not to use Teflon tape on PVC fittings.
I'm probably going to regret using a PVC threaded fitting on a brass spigot.
I turned on the water in the shop and found that the brass fittings on my water heater leak, and one of the brass filtings on the plastic water filter housing is leaking.
This is the water heater. It came with the first brass fitting because the fitting on the heater is an odd size (metric?). I added brass Sharkbite fittings to it. It’s leaking between the brass fitting and Sharbite.
In the meantime, I wrapped the sharbite fittings that will be in the ground with Sharkbite tape.
Here's the new water meter connection.
Here it is wrapped in tape before I fill it all back in with dirt.
I'm about tired of this plumbing.
And if this isn’t fun enough, my daughter and son in law are waiting for me to finish it and go over and help them fix a broken hot water under their slab in his office.
