My New House & Workshop
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
I looked at a house a few years ago with a very steep driveway that went into the basement. I can’t imagine that basement doesn’t floor regularly.
There was also a tunnel that went under the yard to a detached garage. That was really cool.
I see a lot of spilt level houses around here with garages on the lower level.
sgtsandman
Aircraft Fuel Tank Diver
12,687
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Yeah, I imagine that sloped driveway just funnels all kinds of water into the garage, unless they have a trench drain running across the entry way. Better keep that drain running well and clear though.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,782
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
My last house was a raised ranch. The garage was under one end of the house, but the garage door was level with the ground. I never had water run into it.
On another note...
I spent a week cleaning up my yard. Cut down a few dead shrubs that had grown into trees, and cut the ones that were still alive into big shrubs.
Decided to rent a u-haul 5x9 utility trailer to haul it to our local recycling center. Also hauled of the rotted doors I replaced on the shop and a few other items of junk.
I made 3 trips and even had 6 bags of leaves stuffed in the bed of the truck on each trip.
In case you're wondering, there's 69 large lawn trash bags in that pile.
scotts90ranger
4,411
Dayton Oregon
2.3 Turbo
Glad I don't have to do that, the 5 heaping ranger bed loads to the burn pile of apple tree trimmings would have been more than that... Next step is getting the blackberries under control (which will never happen, but I can try...)
On another note, there's a very slight angle on my driveway toward my garage, under very heavy rain some water will seep a couple feet into the garage, on the very long list of to do's is get some drainage figured out for that but first step is to just get the stuff out from in front of the garage, but the to do list is too long to get that far...
mtnrgr
758
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
Doing a great job on your house and property, I like how your making a home for yourself.
Are those husky contractor bags? If they are you can fit anything and everything in those bags. Have used hundreds of those bags thru the years.
Jim Oaks
Administrator
Supporting Vendor
8,782
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Thanks.
A guy actually stopped as I was loading up the truck and told me he liked what I was doing with the building. He said the previous owner never saw the potential of the building and was glad to see someone doing something with it.
I really appreciated the compliment.
Jim Oaks
Administrator
Supporting Vendor
8,782
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
After replacing all of my waterline in the yard, cleaning the yard up, and helping fix the leak at my daughters, I'm finally working on the bathroom in the shop again.
I took the furring strips down, drilled more holes, and ran the 3/4" waterline through them from the exterior wall. The 3/8" copper line coming in under the building no longer flowed water.
I closed the wall up with drywall:
And then covered the drywall with a sheet of paneling.
Then I primed this panel and the original panel to the left of this photo and then painted them white. I still need to put my brick paneling over the furring strips and cover the water line.
The shadow from the light makes the wall look like it has a bend in it.
Here's the outside of the wall with all the water and drain lines:
I removed the old door and door frame and installed a new one:
Seems like this project has taken forever, but it's slowly getting there.
rumblecloud
1,126
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
One step at a time. Projects like this can easily overwhelm you if you are not careful.
It looks really good.
Rick W
3,970
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
Seems like this procet has taken forever, but it's slowly getting there.
Looks terrific!!!
Uncle Gump
Token Old Guy
13,501
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
No utility tub in the shop?
rumblecloud
1,126
48022
Ranger Splash
Stock
Geez Gumper...talk about dumping on the guy's parade ....:ROFLMAO::ROFLMAO::ROFLMAO:
Uncle Gump
Token Old Guy
13,501
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just know it would be one of those things you wish you would have done while you were in there at some point.
SenorNoob
583
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I was lucky that my place came with one. I've used it plenty.
sgtsandman
12,687
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I know it's rather inconvenient to hace to go into the basement of the house to scrub up when I'm all greasy and grimy from doing work on the trucks. A utility sink in the garage would be real nice and it would prevent getting dirt and grease on everything I touch going into the house.
Jim Oaks
Administrator
Supporting Vendor
8,782
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I have a vanity to go on the wall outside of the bathroom (opposite side of the wall) that will have a single basin stainless sink in it. I had briefly considered putting a utility tub on the shop side of the wall but decided against it. I've had a utility tub before and never really used it.
