Junk Collector
Truck of Month
- Mar 4, 2008
- 4,800
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
So I picked up a really cheap 1998 Ranger that has an interesting rear axle in it. The guy I got it from originally wanted to buy one of my spare 7.5's because he had broken whatever was in it, but ended up buying one from elsewhere. The story I got was that he went through somewhere around 4 axles in a matter of a few months. I have no idea how or why or any details, but needless to say it did not have the correct gear ratio when I got it.
So I just happened to have the spare axle on hand (from a '91) and swapped it into the truck. It fits and works perfectly.
The weird thing about the axle that came with it is that the spring perches are almost 2" further apart than they should be for a Ranger. The PO said that he had to use a hi-lift jack to spread the leaf springs apart in order to get the axle bolted in!
So what could this have come out of? It is missing the tag and other identifying information, but it is definitely a Ford 7.5. It has an ABS sensor on it, and the "new" style drum brake hardware, the cable for example has the little box and spring thing which would be right for a '98 instead of the old style straight cable. It also has the large pattern pinion flange. I doubt he swapped brake hardware into it because everything was rusted together into a big mess - the rear brakes didn't work and probably haven't been taken apart in many years.
It is just confusing the hell out of me because I am not aware of any vehicles that this axle would even fit in, and it definitely does not fit the Ranger, at least not very well.
