Peter Griffin
- Jan 30, 2023
- Reaction score
- 365
- Location
- Quahog
- Make / Model
- Ford Bronco II
- Engine Type
- 2.9 V6
- Automatic
- 2WD / 4WD
- 4WD
I wanted to post this separate from my build thread. Mind you I've only doing some preliminary investigation but I'm confuzzled (confused + puzzled) by what exactly this harness is supposed to be plugged into...?
Driver's side, I found lying between the frame rail and transfer case, I re-positioned it so it's easily visible in the photo. Checking the Chilton manual it appears that the wiring harness(es) for the transfer case are where they should be and plugged in, and as far as I know the 4WD works and there's no codes, etc. that I'm seeing...
With the body lift I can see all around the transfer case and the area this harness terminates pretty well but that's definitely not to say I haven't missed something...which may be gratuitously obvious!
Thanks in advance as always for everyone's help, I very much appreciate it!
