Dirtman
- May 28, 2018
- Reaction score
- 13,329
- Location
- 41N 75W
- Engine Type
- 2.3 (4 Cylinder)
- Automatic
- 2WD / 4WD
- 2WD
- Total Lift
- It's up there.
- Total Drop
- It's down there.
- Tire Size
- Round.
- My credo
- I poop in the furnace.
Just changed the intake manifold gaskets and slapped it back together, truck drives and idles smooth but idle was a tad high (950). So I unplugged the IAC and nothing happened. So first thought was a vacuum leak, did a smoke test and found a small leak at the vacuum port on the back of the manifold. I repaired it, reinstalled it and smoke tested again, this time no leak.
Now the truck will idle down to the proper rpm (850) but again, unplugging the IAC makes NO CHANGE in idle speed.
Fuel trims are also all over the place +15.6 at idle long term but bouncing around -2 to -7 short term. Hit the throttle and long term goes to zero. Another classic vacuum leak sign.
Also there's a line from the brake booster I cannot figure out the purpose of.
The red line comes from the air intake hose (non vacuum) but T's into the line from the manifold (under vacuum) that goes to the brake booster (blue line) WTF is the point of the red line. How can there be a non vacuum line connected to a vacuum line?
Right now I have all the lines just disconnected and plugged off to rule out leaks there but still seems like theres a leak someone. Smoke test not showing anything and either is the old propane test.
Wtf!?!?!?!?!
Any ideas here... im too frustrated to deal with it anymore.
Wtf!?!?!?!?!
