Narrowed 8.8 mountianeer rear end
byrdper
I have a 1997 mountianeer rear end an would like to narrow it to go in my, ranger.
Seem's you can cut the long side to equal length of short side an use 2,
short axle's.
Is there an article on here that give's the info. ????:headbang:
Thank's Mike
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
byrdper
Yes it will but it's longer than the factory rear end. I will be using wide rim's & tire's,
an need the room.
byrdper
I have been told there is a post on this site with the info.
I just cant find it.
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Not to say it's not in here somewhere, but all I've seen is a front solid axle narrowed like you describe. And I can't find that thread either.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Do you have a 7.5 or 8"? That info would be helpful.
Sent from my iPad avoiding something that I should be doing right now.
byrdper
It's an 8.8 / 31 spline axle disc brake rear end out of a 1997 5.0 mountianeer.
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It may be cheaper to find the right offset rims to tuck the wheels in.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Problem with doing that is the driveshaft can get into fuel tank. This is why its offset in the rangers, but not the bronco ii's or the mustangs. Cutting the axle down is as simple as cutting the housing straight, beveling the ends then making multiple passes to build the tube back up, then grind flat. I've done it multiple times, and I think its in my SVT build thread somewhere...
SVT
byrdper
Thank's ranger STV
It get's a rear mounted drag car fuel cell so no problem with fuel tank.
I need all the room i can get to stuff a set of fat tire's .
Trying to work around tubing it.
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
235/70R15 front / 275/60R15 rear
Thank's ranger STV
Well here's what I did...........I narrowed mine & did the Explorer style (leafs under frame) mod......15X12 Draglites with 28X15.50 tires:
byrdper
chvlfrk Look's great this is just what i am trying to do.
Did you have to make more inner or outer fender room ?
What spring hanger kit did you use ? :icon_welder::icon_welder:
Thank's Mike
turbo91xlt
63
Goshen, NY
1992
byrdper
THANKS MUCH , this is what i was trying to find.:yahoo:
chvlfrk
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
Thank's Mike
No mods to outer wheelwells.
I had to remove some of the support brace on the bottom of the box, but didn't have to tub it.
I used Explorer front spring hangers and made my rear shackle hangers.
