Need 5spd
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Looking for 5spd near Southeastern NC! Any help would be appreciated thanks
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
For 89 bronco ii
8,372
Welcome to the forum
car-part.com
Good place to look for used parts in you area, zipcode
1989 BII should have a Mitsubishi FM146 4x4 trans even if its a 2WD
I would switch to an M5OD-R1(M5R1), from a 1990-2000 Ranger/B-series 4.0l 4x4
Bolts to 2.9l and transfer case
Can then use 4.0l flywheel, clutch and starter, its an upgrade, lol
Article here on that swap: https://www.therangerstation.com/Magazine/January2011/FM146_to_M5OD.shtml
M5R1 was used from 1988 to 2011 Rangers and B-series, very reliable transmission
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Thanks Ron. Trying to help a friend out. I’ll be sure to pass the info on! Live near Wilmington NC 28461 zip code. Anyone around this area hit me up
YepIt'sMe
9
Florida
car-part.com
I stayed with the FM146, as I don't run it hard (but more-so...'cause I didn't know any better at the time ;) ). I did do the 5th gear update.
Had some difficulty sourcing an Inner Shift Lever Boot;
Howe Racing 223991 Howe Precision Ball Joint Boots | Summit Racing
Also had to fab a Shift Lever Lower Bushing from a Nissan oem unit;
Shifter lever bushing cup for Nissan RWD cars & trucks w/ early FS5R30 - 20mm OD | eBay
Both efforts took substantial measuring of/searching for parts.
Sourcing parts IS an issue for the Mitsubishi units.
A call to Ford yielded a LOL.
Mitsubishi said "You want what?! "
Sooo, the pictures tell the story.
I used decreasing git sandpaper to mill the outside diameter with it in the drill press.
Used the Dremel carbide bit to "sculpt" the inside "cup". :)
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Good work!
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Got the transmission issue took care of! Thanks for all the info!
