Need a diagnosis! Pulleys, belts, or transmission?
Biggie
US
My 2.9L with an A4LD has begun making this noise at around 4000 RPMs, but once I drop below or gain about 500 RPMs the noise goes away. What gives?
Sorry for posting twice in such a short time frame, just trying to get as much information as possible.
rusty ol ranger
2.9 Mafia-Don
7,811
Michigan
177 CID
Check the tension on your belts. Thats classic RPM induced belt squeel. If tightening dont help replacing or even a good helping of belt dressing will help
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,658
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I could be wrong... but it almost sounds like your clutch fan is locked up.
alwaysFlOoReD
5,199
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Can you replicate the sound while parked? If so, remove the belt and see if the sound goes away. But I agree with Rusty, that's classic loose belt noise.
Biggie
US
What would be the proper fix? Get some WD40 or other lubricant in there and see if it helps?
8,383
No, a belt squeals because its slipping, so lubing it would opposite of what you want :)
"Belt dressing" makes is stickier, softens the "rubber" so it grips better
Biggie
US
Gump thought it was the Clutch fan, that’s what I was planning on WD40’ing. Putting dressing in a locked up part is definitely a unique strategy though.
8,383
Fan clutch locked tight would cause belt to slip on water pump pulley, I don't think you can lube the fan clutch externally
With engine off just see if fan can move, if so its not locked tight
