need a lil help about wiring
puffnnos
belvidere nc
well i got a 88 ranger that im workn on puttn a 302 in it and cant get power in the cab which when i switched the motor i un plugged the harness off the fenderwell an left the wiring on the motor an sold it if any one can help thanx
Sighman
04/2011 & 04/2014 MTOTM Winner
MTOTM Winner
Canton, TX
302
Are you saying you got rid of the whole wiring harness with the old motor? When I put mine in I used the old wiring and just got rid of the plugs I didn't need. Everything in the cab still works even though I have the computer unplugged. I figured it was easier that way instead of having to rewire everything from scratch.....If you have no harness you might have to go buy one from a junk yard or from "Painless" or make one yourself....
kimcrwbr1
46
maplevalley WA
2.8l
If your doing the duraspark all you need is the alternator ignition on and start wires. The power to the ignition is not in the engine harness it comes from the start solenoid with a fusable link. once you get the fuse block powered up then you can work on the engine wiring. +1 on the engine harness from the bone yard you can strip it down so you have the wires for the alternator,oil,coolant and tach just grab the senders off the donor vehicle if still there. Then just plug it in you can pull the power to the coil and module off the engine harness and use the start wire on the start solenoid for the white start wire for the module. There should be a large round connector by the start solenoid you removed when disconnecting the engine harness it goes on the battery side of the solenoid. that powers up the chassis harness and fuse block. Being a 88 if you have the power distribution center that get power direct from the battery with 89 wiring.
puffnnos
belvidere nc
yea i didnt know i would need the old harness to have power in the cab have the motor running jus no power in the cab i have to jump the solenoid to start ittho
Psychopete
29
FW, IN
If you gave him only the engine harness, you are OK as that is separate. There's a wire w/ a fuse link near where the starter solenoid is/was that needs to be on the batt side of the starter solenoid. Once that is connected, then you will have power to your cab. This wiring is separate from the engine related main harness.
If this was removed, will have to get one from a j/y, get it back from that guy cause he don't need it, or get an EVTM and just wire it up yourself.
Edit, if you had an auto (not sure about manual) you neurtal safety switch will cause a no start since part of the circuit DOES run in the engine main harness. I subtracted this circuit from my mainharness so that I could retain the plugs. oil pressure, temp, etc all run through those dash plugs also, gave a way an important piece IMO, but not a deal breaker.. :)
puffnnos
belvidere nc
well i have no power to the fuse link i might have it backwards but the engine harness is gone and i had on pass side fenderwell a starter relay an a fuel pump relay i removed them an the computer an the wires goin to the computer prolly a mistake but didnt know i running a caburated 302 an running a msd coil an 6al box wit stock distributor i took on this project a lil to much cause swappin dana 44 axles and full size 302 motor trans a t case
Psychopete
29
FW, IN
You know what wire I am referring to then? I don't have my EVTM handy to verify the color, but the power to your cab has nothing to do with the engine main harness (but I suspect the nss will be your next project to tackle). Will have to look in my manual later tonight to see what color that will be, but needs to have constant power / needs to be on the battery side of the starter relay to get power to the cab.
puffnnos
belvidere nc
yea had the fuse link backwards an the solenoid but there is one more question i gotta ask my motor trans an t case is out of a 89 f150 was efi i switched it over to a carb but guy told me cause i am runnin a aod trans i gotta put a pressure guage on trans an adjust the kickdown linkage or it would burn it up
kimcrwbr1
46
maplevalley WA
2.8l
Isnt the AOD a four speed auto. You want to adjust the kickdown cable with WOT and the tranny lever to its stop. Keep the shift lever in third when pulling hills or just driving around town. At least that is what by brother used to do.
mike732
Camden, TN
302
If the linkage is not hooked up correct the trans will not last 300 miles, use a pressure guage don't risk it.
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
