Need a Measurement
WNY964x4
ASE Master Certified
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
alot of different ones
as the title says i am looking for a measurement or 2
the measurement i am looking for are for the following things on a 3rd gen ranger
1. outside of frame rail to outside of frame rail , directly behind the front bumper
2. center of tie rod end stud to center of tie rod end stud of a truck with known good alignment
thanks to all that help me out
EDIT: I would also like a pic of the steering linkage , particularly the center link , as looking from the driver side toward the passenger wheel
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
can anybody help ?
nate09
6
green bay, wi
outside to outside mine measures 30 1/4"
driver to passenger
passenger to driver side
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
thanks nate , i just measured the frame and it is still fine
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
can anyone get me a pic od the driver side frame rail looking straight up at where the gearbox mounts ?
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
my frame looks like that on the outer side where the gearbox mounts , what aboug yours ?
and here is where the box is mounted
89PBR96
Pekin IL
Need any other pics man or help
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
PBR , can you tell me if your frame is perfectly square where the gearbox mounts , or if the outside edge of the rail has a "hump" in it around where the bolts come through ?
89PBR96
Pekin IL
Not sure what you are asking really it is pretty flat it turns into more of a rectangle in that area
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
actually PBR you got it dead on , so now i know there is nothing wrong there , so i still have yet to figure out my steering issue , but now it is down to 4 things : 1. Linkage , 2. Shaft , 3. Box , 4. Knuckle
89PBR96
Pekin IL
Can you not get the tie rods adjusted proper? or is the steering messed up
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
that is looking down my frame rail , i cant tell if that looks right or not
89PBR96
Pekin IL
It looks like mine from what I can see it's pretty smooth tell the spring perch has the impact divits right up front other than that it's flat
feellnfroggy
28
Knoxville, TN
What problem are you having with your steering?
