Need Airbag Wiring Schematic
torquewrencher
mobile,al.
1984
FORD
FORD
3.0 and 2.8
maintain to work as advertised
Hello, I am trouble shooting a airbag code 52. I know it means the backup power supply voltage is low or no voltage. I have checked all the fuses and they are good. I had the battery disconnected for a day while working on the engine and that is when the code showed up. I need a wiring schematic for the airbag system on a 1997 ranger to trace the wiring and check for voltage and continuity. Please help if you can.
Thank You in advance for any help you can give. :annoyed:
black_demon69
142
AZ
4.0l
why not clear code to see if it is ok or not? as you said you did have battery disconnected
torquewrencher
mobile,al.
1984
FORD
FORD
3.0 and 2.8
I do not know how to reset it. My OBD scanner will not do air bags. I have not resolved the issue yet. I forgot to mention the fact that I had the battery disconnected because I had the wiring harness plugs at the firewall disconnected. That's why I want wiring diagram to chase the wires.
