Profive.oh
- Aug 15, 2023
- 8
- Oregon
- FX4 level ll
Just like the title says I need some input on getting the Speedometer to work. I did the 5 L swap then I decided to swap out the cluster with one out of a 2003 ranger because it has the sweeping gauges and not just dummy lights. The factory gauges had two 20 pin connectors and the 2003 had three connectors one was a 16 pin and one was a 12 pin and the other was a 10 pin so I just match the functions up the best I could and soldered the wires together. Well I got everything back together on the truck and the gauges and tach work correctly, except the speedometer/odometer is not working. I hooked up the Pin# 5 VSS gry/blk on the truck harness plug-in C220A to the Pin# 1 SPEED INPUT gry/blk on the explorer harness C287. And I hooked all the other wires up that accommodate the earlier cluster speedometer like the ground, constant power wire and the hot in run or start wire yet it still don’t work. 2krngr has a thread on here where he did the same thing and everything worked including the Speedometer/odometer but I haven’t heard from him sincè September 10th. Any input you can give me on this would be greatly appreciated! TIA
PS: the factory gauge cluster would not work correctly, the temperature gauge was calibrated differently and the tach was off also because it was for a 6 cylinder.
