Need help to ID cab plastic trim pieces.
Oxxon
51
Brownsville, Tx
I have a 2002 XL Ranger Reg cab and I'm looking to replace missing and broken trim pieces. For the life of me I can't remember what these parts are called so I can try to hunt some down. The driver side is missing and the passenger side is broken. Any help will be appreciated.
Bird76Mojo
1,265
IL
I always called them sill plates. Others might use rocker cover.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Piece you have highlighted is called a threshold plate, and the larger piece next to it is called a door sill plate cover.
Grumpaw
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
i call them kick panels. its where i tap my foot before getting in to keep all the sand out. sand has wore holes into my floors on almost everything i drive. ? living in florida is rough. ?
Oxxon
51
Brownsville, Tx
Thanks for the responses. I found what I needed with your help.
The kick plate is the one in the foot well below the dash, outboard of your feet.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
i know. i call them that anyways. i have had several discussions on the subject. because i dont kick it ? i call what i actually kick, the kick panel.
