rekles
- Mar 4, 2015
- 3
- lake havasu
- Ranger
- Engine Size
- 4.0 ohv, 4.0sohv
Ive had this truck project going on for a year or so now and i am finally starting to get it where it almost 100% done and i can drive it again.
I started with a 99 4.0 ohv xlt 2wd automatic. I blew the heads on it so it sat for a while.
I came across a 2002 4x4 automatic 4.0 sohc xlt that had been rolled but the engine had low miles on it and ran great.
I eventually pulled the sohc engine out and put new timing chain kit with gaskets and cleaned out the engine as best as i could without pulling the heads off. Got a newer 2wd transmission to work with the sohc engine then dropped it into the 99.
I also found tan interior for super cheap out of a 03 i believe so i swapped over the dash too.
i finally got everything but the vacuum lines hooked up and it would not start.
Used a little starting fluid and it fired up for a few seconds, figured out the inertia switch was not hooked up so i spliced those wires together and it fired up for a second then died.
I came back the next day to mess with it again but no dice . it smells like it is getting fuel and ive been using starting fluid but it wont start at all. i checked the spark by hooking up a spark plug test light and everything looked good.
so far i have new belt, plugs,fuel filter air filter, and battery.
what should i check and what should i look for?
also no cel and i am using a different Gage cluster than what came from the 2002 doner
As always thanks for any and all help
