need some opinions...98 V8?, or...?
stillwater
Indiana
1998 Ranger XLT
2.5
I recieved a 98 2wd shortbed Ranger a few months ago in a trade.
Please forgive me if I've asked before, as I had a stroke sometime ago and don't always remember what I've already asked. I've been to several forums, most say to come here. :icon_idea:
Anyway, as I read through here I get the impression my 98 isn't as swap-savvy as the earlier trucks. I also got that impression from my friend (without him saying as much...)
Where I live, there are no emissions requirements to comply to. By doing my research, looks like the easiest/cost effective swap will be a 302 (a 289 would do too). And I'd run a mild cam, headers, 4bbl carb, etc. And an 8.8 rear end swap also in the future. Better brakes too- brake swaps? is there info for that here too?
My truck sits much higher in front than the back, has 2.5 auto in it. No lift contraptions, old owner was convinced maybe there had been F100 spring swapped under the front...when I V8 it, I may need extra lift but I don't think I need that much.
I guess my concern is- should I use this truck to swap in a V8, or would it be far easier to use one of the older ones? It isn't in real bad shape, just lots of miles.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
this is a depends answer.
easy and or cost effective. that needs power goals to have definition.
Junglejoe
66
Columbia Missouri
6.0
Actuall the 98+ trucks seem to be the easiest. Only problem is there is only two types of aftermarket headers that fit these trucks. That's not a problem if its just a daily driver, use the explore/mountaineer cast manifolds . They are a lot better than the early ones
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
or just mod the steering shaft and run whatever header you want.
ls engine is generally the most cost effective for power.
stillwater
Indiana
1998 Ranger XLT
2.5
Quote bobbywalter- or just mod the steering shaft and run whatever header you want.
How is this done? I have an old S10 swap manual, perhaps I should look at it some...
Quote-Junglejoe Actuall the 98+ trucks seem to be the easiest. Only problem is there is only two types of aftermarket headers that fit these trucks.
Which two brands or types? I definitely want headers.
stillwater
Indiana
1998 Ranger XLT
2.5
Another concern is the heater motor box (I think..) needs heated and bent in?
Forgot to add that I'm going to use a C4 trans too. And keep my AC.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
well. the header issue is caused by the gt40 p head. theres a shit load of headers and manifolds that can be used with normal heads... or custom boots and shorty plugs.
if you have a good ol 289 that is not an issue.
you can junkyard or big bux buy from borgenson..... steering joint and shafts and put a hiem or pillar block out by the shock mount to redirect the steering.
30-50 dollars worth of jy and order parts or 600 dollar headers that dont make it easier to work on..
up to the owner.
1st time is always harder. 1st time for me was in the 1980's so these are more lego to me then anything.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
heater box should clear 5.0....and minor mods for 5.3 gm.
for 300 plus hp running take out swap, my first choice would be a 5.3 or 6.0.
if you want a ford, the 302 is golden...but not for 300 hp without work and money.
for a 2wd play toy the 302 with a duraspark or flamethrower/dui setup with a 600 cfm carb seems ideal.
but i can get more power cheaper via the 5.3 with efi. of course they are aging out for the earlier styles for low miles and cheap/easy to work with now like the 5.0. but the newer units can make big power too.
i use most effective package for my current need/goal. and there is always compromise. i would prefer to have a ford but they do not make what i need so i used what fit best. at least i can use a 4l80.
