neon srt 4 seats
03Fx4MN
Lake Elmo, MN / Jacksonville, NC
has anyone ever thought of these??? look aftermarket and I've sat in them and are actually quite comfortable with a lil seat track mod:icon_welder: they should work like any aftermarket seats right??
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
:bad:
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
if the space is there for them, i'm sure you can mod the tracks or make new ones and bolt them in there. seems like i read another post where someone used those seats. good luck! :icon_thumby:
scrapper
63
central IL
1975 302
did anyone ever try these? I got a set.
ericbphoto
Overlander in development
16,650
Wellford, SC
6"
Somebody toss me a set and I'll give it a try.
Ozuye10
24
VA
I owned 2 SRT-4’s, those seats are great!
scrapper
63
central IL
1975 302
I got drivers side in. It wasn't bad. You have to grind 4 rivets on 1 side and 3 on the other to get the brackets off the back. You need 2 strips of plate to get the holes to match up. The seats are 15 inches wide and the rangers are 14. I used 2 stove bolts countersunk to mount the strips of metal. They don't interfere with the slides that way. I just used the front seat holes to mount the metal they are threaded 6m bolt holes. The strips were ran left to right. Not front to back. The only down side is the seats don't fold forward only back. I set in it and it's comfortable
oldgeek
1,027
USA
Ranger XLT
What cab do you have?
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
@scrapper Are those seat more comfortable than a stock Ranger/Explorer seat. TBH they look a little "meh".
scrapper
63
central IL
1975 302
I have to say felt really good when I set down. I put the strap on with a stove bolt to hold it in the stock hole. I still have to do the bottom one.
superj
2,624
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
look like you aren't going to slide around in the seat at the autocross
scrapper
63
central IL
1975 302
Passenger seat ready to bolt in
scrapper
63
central IL
1975 302
I'm going to have to find the explorer center console and paint it black and install it. I think it will look nice.
