American1990
- Dec 10, 2010
- 0
- Conyers, Ga
- Ford
- Engine Size
- 4.0
- My credo
- Build it, Break it, Re-build it stronger.
Ok, So the last couple days my truck been broke down. A couple days ago my Transmission (FM146) would no longer shift into gear, I even had a hard time putting it ion gear with the engine was off. So I went and put a M5OD behind her with a brand new, clutch disc, pressure plate, pilot bearing, and fly wheel. Still same problem but now when I crank up with it in gear she takes off like a rocket. And i cant shift into any gears while the engine on, with it off I can. I have Just replaced the master cylinder and slave cylinder (also throw out bearing) and still same problem. I have Bled the clutch 500 times multiple different ways, and even after driving around in 2nd for a ways still nothing. I cant start the truck up in neutral, but cant shift into gear. I can start the truck up in gear but she takes off, even my brakes have trouble holding me. I am just at as total lose, I don't know what to do. I could really use some advice, I need her back ASAP.
