New Clutch Time Advice Please
Warmblood58
Fairfax, CA
4.0L OHV
Maintain it dammit!
So my '92 4x4 4.0 Ranger's clutch is starting to slip . . . this explains previous stinky clutch smell that I have noted in the past just feathering the clutch. I know that I will need to resurface flywheel and because clutch slave on my trans is internal, will need to replace this along with pilot bearing, throwout bearing, etc - and rear seal too as now would be the time. My question is should I buy a heavy duty clutch disc (do they make one) and pressure plate from Ford and go OEM or is there a much better quality heavy duty clutch and pressure plate out there? Any thoughts? Thanks folks!
94sport
Hamilton, MT
when I did my clutch recently I just bought a new flywheel for 30$, but I used a SOHC clutch(LUK 07139), its larger in diameter than the OHV clutch. also be sure to use a motorcraft slave, and If I were you I would just change the master too. Also buying prefilled is a godsend because bleeding these clutches suck.
Warmblood58
Fairfax, CA
4.0L OHV
Maintain it dammit!
Wow, flywheel only 30.00?! It was an oem flywheel? I think machining would run more -thats amazing. Do you have a '92/93 4.0 also?
94sport
Hamilton, MT
It was a LUK flywheel but from my knowledge they did the oem Manual parts, and I personally have a 1994 ford explorer. I know the master/slaves were different between years thats why I suggest replacing it all.
here is the slave i used :
https://www.amazon.com/gp/product/B008Y84T2K/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
coupled with the newer SOHC clutch the clutch pedal is as light or lighter then my ford escort, and grips really well.
Warmblood58
Fairfax, CA
4.0L OHV
Maintain it dammit!
Thank you! And rated just fine for 4x4 I assume? Yea, I understand those hydraulic components are problematic to bleed. I will be taking my truck to a shop for this work as this work way too heavy for a single man job without a lift
94sport
Hamilton, MT
awesome well I hope it goes well! and yes fine for 4x4
