koa's93ranger
- Jan 12, 2009
- 2
- Las Vegas
- Ford
- Engine Size
- 4.0L V6
Seen a few ppl do this. Seems strong enough but what about my variation.
Think of using this same design, but instead of a rod end, use the gm tie rod insert to attach a tre. I could go with the rod end but I figure the tre would have less slop and last longer.
Not sure whether I should just weld the insert between to two plates, or weld in a 7/8 id piece of Dom and put the insert in that.
Last variation...instead of running this bracket between the two leaves, which causes a lot of bump steer. What if I make this bracket ~4 inches tall and run it over the passenger leaf? Will this be too much leverage on the weld?
Tips, Ideas, comments, insults??? Much appreciated
