Newbie from UT
Kanoodle
SL,UT
Mazda
My name is Dustin and I just bought a 98 B-4000 auto 4x4 with 126,XXX miles Tues night of this week and now have a growing list of "need to do's". I apologize in advance for the book I am about to write lol.
First thing was the 4wd and 4wd low would flash when I put it into 4wd. Unplugged the battery to reset the code and tried it again same thing, I crawled under to see if the plugs were all snapped together and they were. So had the gf come over and put it into 4wd while I smacked the 4wd motor after I reset the code and it is now functioning. So went down a dirt road to test the 4wd and nothing. So read up on the auto hubs did the lock mod and tested it again the next day, success.
Now I have noticed a small coolant leak. It is coming from the valve that hooks up to the heater core by the firewall. Idk what the valve is called but that will be getting replaced soon.
The overdrive lockout wasn't working so I checked fuses and bingo there was one popped. I replaced and now the O/D lock out works.
Next big issue is FILTHY coolant. Going to flush the system out tomorrow. Any pointers on this procedure would be great.
So I noticed today a whining noise coming from what sounds like the hubs after the hub lock mod. They are in fact locked so should I be concerned?
The ATF is fairly filthy so going to be flushing it soon along with diff, and T/C fluid change.
The font end may need a few bushings and has a small clunk. Does this site have a vender and anyone have a link with front suspension components?
I do have a question about the rear end. Do they have a locker or ford version of limited slip when in 4wd?
It has a small miss at idle to 1500rpm is this normal in the 4.0? I am going to change my spark plugs to see if it helps at all.
Anyways for you that are still reading I could go on for DAYS so I am going to stop my list here lol.
RICO9
07/2014 OTOTM Winner
35
SL,UT
Title says 84.
Furd
2.8L w/ Chevy TBI.
Welcome to the site from West Valley City! What part of UT are you from?
prerunnerwannabe
10
UT
Welcome! Yeah what part of UT are you from? I'm from the Logan area.
4.0B2
151
Walls, MS
4.0 v6
Welcome.
A lot of your questions can be answered with the tech library.
Ford did offer a limited slip... Check your data tag on the rear axle or door code and consult the tech library.
Let's see some pics of your ranger!
Oh and btw when I first saw UT, I thought rocky top! I'm a Vols fan so I can't help it! Welcome again!
Kanoodle
SL,UT
Mazda
I live In Taylorsville (Salt Lake county) but moving to Midvale on the 6th.
RICO9
35
SL,UT
Title says 84.
Furd
2.8L w/ Chevy TBI.
Cool! you guys should come the monthly meet and greet at the Hire's burger joint on 4500s 3000w. a bunch of us members will be there next saturday at 7pm.
Kanoodle
SL,UT
Mazda
I might come mingle but the truck wont be present, changed the coolant and turns out it wasn't just dirty it was pitch black. There is a decent amount of oil present, I drained filled with water, turned the heater on, drove around to flush the water through it and drained it, and was still very dark. So I am either going to replace head gasket, swap another 4.0 into it or just put new fluids in it and sell it untill i find another really clean truck.
Hires is less than two minutes from my house so I will most likely show up in the Mazda Protege to meet some of the locals.
RICO9
35
SL,UT
Title says 84.
Furd
2.8L w/ Chevy TBI.
that's cool. My bronco hasn't made it to a meet yet. I'll be in my Jeep.
