no 4x4 low
93 4x4
florida
Having a problem when I push the bottom I can get 4 hi push 4 low nothing happens check the fusses all look good,the shift motor is one year old. whats up.I think I know what my next swap will be! Why would ford use these pos's! thanks
KTM RAPTOR
Ontario, Canada
2.9
shifter motor :icon_confused:
Keep us posted..
93 4x4
florida
only lasted one year
bilzy7
32
Lynn, MA
4.0 SOHC
Neutral then 4x4 low?
93 4x4
florida
yep, the light doesn't come on nothing happens are there different fuse's or relay's? changed out the dash switch same thing
bilzy7
32
Lynn, MA
4.0 SOHC
Isn't 4x4 fuse in the engine bay?
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Sounds like it might be your control module if you dont hear a click from it (it's in behind the driver side booster seat ) You might also want to swap out the switch itself. They go bad, but not very often.
93 4x4
florida
yeh, one single click when I push 4x4 low I'd hate to buy another motor and find out thats not it
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
I'll reiterate. Did you check your control module? (that's NOT the switch or the motor) Its a completely different part
